RAIL PRESSURE!?!?
Old Oct 20, 2013 | 10:49 PM
newborn GOAT!'s Avatar
Default RAIL PRESSURE!?!?
Need insight on my 07 32500 5.9 6spd fuel rail pressure... @ idle it seems to be right in the mix of normal being between 6-7k... that bein said cruising at around 60mph/1800rpm it stays steady around 20k... ANY increase of throttle and she drops to about 17-18k or a little lower untill my foot levels out... am i where i need to be or does this seem off!?
opions and inputs of any kind would be awesome!!
proud 3rd gen CR owner...
Old Oct 20, 2013 | 11:19 PM
97cummins's Avatar
It sounds about right to me. I would keep an eye on the pressure and if it really starts dropping then you could have an issue stating.
Old Oct 20, 2013 | 11:52 PM
so normal!? trucks basically stock except for 4" stright, K&N cool air, and BD boost fooler...
on another note... any knowledge on boost psi at the top of any gear?? avg??
Old Oct 29, 2013 | 06:06 AM
97cummins's Avatar
yea, sounds normal to me
as for the boost pressures, sorry, I don't know.
Old Oct 29, 2013 | 08:43 AM
4x4manonbroke's Avatar
ur posted in the 12 valve area.about a CR ......... have u posted this in thd 07 area .... more guys might have more info on these because they own one ... just askin ?
Old Oct 29, 2013 | 09:09 AM
yeah posted it in the 03-07 but figured more would see the post if i hit it up on the general posts.. thanks
Old Oct 29, 2013 | 12:20 PM
jigabop's Avatar
was gonna say...this isn't the 12v area....
Your pressures seem alright. but I'm not a CR guy either, so I'm not 100%
if you have stock injectors, chances are you won't be able to pull your rail pressures dangerously low even with an aggressive programmer...
usually takes aftermarket injectors to create a need for an upgraded/twin CP3 pump setup.
however upgraded lift pump never hurts as the stock lift pumps can't keep up with aftermarket mods on any generation truck.
also throw the K&N filter in the trash and replace it with a quality dry filter...
oiled air filters + high boost capable forced induction engines = a no no...
the turbo can suck hard enough on the filter to pull the oil right out of the filter gumming the compressor up and allowing dirt through..
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Gitana
Feb 18, 2015 10:08 AM
veggyoilkid
Nov 10, 2014 12:39 PM
growland415
Oct 22, 2014 01:56 PM
