Stalling out
Old Oct 18, 2013 | 12:15 AM
Moonlite's Avatar
Default Stalling out
I have a 99 ford f350 7.3 diesel
Have replaced all injectors
Have replaced high pressure oil pump and IPR
Have replaced cam sensor
Have replaced elect lift pump
Now after driving approx. 20 mikes it stalls out will restart after about 30 minutes. IPR coil is so hot can't touch it so I replace IPR again no difference . Any suggestions?
Old Oct 18, 2013 | 12:19 AM
joebob3093's Avatar
Moderator
Have you scanned it?
Old Oct 18, 2013 | 06:11 PM
Moonlite's Avatar
Yes I did scan it. Said ICP high/low.
Old Oct 18, 2013 | 08:00 PM
joebob3093's Avatar
Moderator
That's usually caused by a chip if you have one
Old Oct 18, 2013 | 10:38 PM
Moonlite's Avatar
No chip that I am aware of. How can I tell?
Old Oct 18, 2013 | 11:07 PM
joebob3093's Avatar
Moderator
If there is something plugged into the PCM or if its a tuner you can't tell
Old Oct 19, 2013 | 12:10 AM
Moonlite's Avatar
Could that cause my stall problem? Do I need to get a new PCM ? I did order new ICP sensor gonna try that only $130.
Old Oct 19, 2013 | 12:28 AM
joebob3093's Avatar
Moderator
Your torque converter could be locking up to early.
fivepointohno
5.9L CR Performance
12
Jan 25, 2016 01:07 PM
Mike0885
May 27, 2015 12:07 PM
RatsMC
May 4, 2015 05:25 PM
1997silverado
Feb 13, 2015 08:11 AM
1997silverado
Jan 23, 2015 05:06 PM
