Fuel problem
Old Oct 16, 2013 | 02:38 PM
freak-n-diesels's Avatar
Default Fuel problem
Sorry guys, haven't been on in a while but i have a fuel problem the is kicking my butt. I have an 03 common rail, this is what i have done and this is what has happened so far. First, in stead of keeping it simple i had went and replaced the injector pump, did not fix the problem of course it always happens to me. Anyway, took the fass pump filters off and found plastic shaving inside from where the guy drilled in the top of the tank for the new pickup tub. Replaced filters and had the pump check out to make sure it still worked properly (150gph). Got fuel to the pump and then still would not start, did a injector block off on each and found that #4 injector was the problem, it was a cracked housing. Put one new injector in and it started, ran it till the smoke cleared drove it down around the block a time or two, pulled into napa and it shut off and would not start. Towed it home and did some checks, now i'm back to square one, no fuel to the injector pump. What's up!
Yes, it does have a 1/2 tank of fuel and the fuel is not getting to the injector pump.
Last edited by freak-n-diesels; Oct 16, 2013 at 02:38 PM. Reason: Automerged Doublepost
burndiesel
10
Feb 7, 2023 01:15 AM
Dbleo351
Nov 20, 2016 09:34 AM
stevew970
Jeep Liberty
Aug 31, 2015 07:56 AM
moneypitk5
Feb 12, 2015 11:01 AM
Colby cummins
Nov 16, 2014 01:18 PM
