LP?
Old Oct 10, 2013 | 10:04 PM
blacksally's Avatar
Default LP?
put a batch of used filter tranny fluid in my truck it started to have no power got a p0251 and p0370 code I opened drain t and it would stay running unplugged LP still stayed running erased code came right back should I try a new LP or clean opitic sensor ? any input would be nice!
the lift pump is working im sure hope its not the IP
I have a bully dog monitor and I can barely hit throttle it says its 45% load??? and left off the throttle says 0 before use to say 1 or 2???? it runs but doesn't have barely any power
I cleaned optic sensor its still runs like garbage im guessing the injection pump is shot or something? anyone have any in point at all should I drain the fuel and put fresh in it?
IP must be working it runs and drives I cracked a injector line and its pourin fuel out im gunna try draining all the trannny/fuel out and try fresh fuel?
Last edited by blacksally; Oct 10, 2013 at 10:04 PM. Reason: Automerged Doublepost
Old Oct 11, 2013 | 01:41 PM
racer55's Avatar
Be vary carefull with the OS,it is installed with prescision and if not put back in exactly the same place it was will cause a lot of problems requiring an IP calibration to correct it.
OS directions:
Roy Halvorsen
Old Oct 12, 2013 | 11:39 PM
blacksally's Avatar
so I put my walbro lift pump in as we talked about getting fuel up to ip then nothing to injectors can it have that much air in it? since before I didn't see much fuel when I took tio off ip? or can the os be making it not get fuel?? I have intake off and hooked up the grounds and my volt gauge doesn't some much oil pressure doesn't go up but I hear lp come on my blinkers lights in dash both show up no day time driving lights etc im at loss idk what to do can afford a ip right now booooo any ideas?
Old Oct 13, 2013 | 03:02 PM
racer55's Avatar
i believe you created a big problem when you cleaned the OS.
Both your codes are from that OS cleaning and not marking it's location before removal.
You now need to take the IP to a rebuild shop with a calibration bench to get it put back in exactly the right place.
Not sure if the trans oil has created a problem with the IP fuel solenoid as well but you may actually need an IP now?
ECM B fuse good?
rest of fuses good?
Old Jan 12, 2014 | 06:18 PM
Ohiomike's Avatar
sorry everyone what is an OS ?
Old Jan 12, 2014 | 06:25 PM
Mayhem's Avatar
Optic Sensor
