f350 no start after long time sitting
Old Oct 10, 2013 | 10:01 PM
bettyford's Avatar
Default f350 no start after long time sitting
aloha, I've got a 1995 f350 cowboy Cadillac that's been sitting in the Hawaii weather for about a year ,wife left, dog died and truck broke....sounds like a country song ....anyways ... I bought new battery's , cleaned the fuel filter and drainedwater, a cup maybe, put sea foam in the fuel...... as well as rebuilt starter, still no start , wait light comes on for 20 seconds or so, all seems normal to start, but nothing happens just a faint click , bought the solenoid that goes near the battery's and wonder if anybodys got ideas or suggestions ? battery were from walmart and seem weak , cables all check as good with new bolts on all , grounds seems tight and sound....oh yeah , jumped the starter and she cranks.... please no" its a ford comments", when she go she go! this is my first forum so please be gentle .... thanks p.s anybody know where the neutral safety switch is? she's got a overdrive auto trans....
aloha, i need help guys...no replys yet...ideas anyone?
Old Oct 11, 2013 | 04:46 AM
SickStroke6's Avatar
The faint clicking sounds like a battery related issue.. While my 04 6.0 battery's were only putting out 1/8th the voltage needed to start my truck it would just click and the lights would flicker as I tried to start it.. Advanced Auto parts can do a battery test and free recharge if you don't have the tools to that yourself. I would recommend getting them fully charged up because these trucks need a lot more juice to start up.
Hope I was some help.
Old Oct 11, 2013 | 08:19 PM
bettyford's Avatar
Default no start
HELP! thanks, got new batterys , interstate 65 type, and firewall soliniod ,the glow plug switch looked old and badly corroded so its next to be changed , there was no clicking that the glow plug should make on start... up so it seems good to change it , neutral safty switch will be next if it still wont start thanks
[if its fixed, don't break it]
so.... new batterys, new starter, new soliniod, new glowplug soliniod/relay, battery connections all good /cleaned and new nut/bolts, checked fuses all look good, cleaned relays , fuse box and checked for loose wire , none found,..... just a click at starter? doing the job alone so not able to locate the click......HELP ANY FRESH IDEAS?
got her started!!!....jumped the starter solenoid with the key in the 'on ' position,[new solenoid] still no start with the key, any idea what the issue is?.... ....next to the stuck brakes........ bigger hammer needed....and a can of break away...wish me luck! power steering not working yet either, gonna jack it up and see if the steerings free, a year is a long time to sit in the rain ....aloha
Old Oct 12, 2013 | 12:35 AM
Have you tried starting while in neutral?
Old Oct 13, 2013 | 12:15 AM
bettyford's Avatar
Default no start,now runs...
yes, tried all kinds of "don't fix what's not broke" then started the "try the next suggested thing" now at the "replace and repair' stage....got her running, still not rolling, going to pull the front breaks and try to free the calipers...all the lights and electrical components seem to be ok... thanks
so ....truck runs,,,working on brakes , got fronts to unlock, Lucas in the power steering all seems good , get in to see if she will roll....frigin key/ignition switch jams , all loose and the keys stuck...WTF? so I guess ive got to put in a new switch....anyone out there done the ig switch on a 95 ford diesel?
Old Oct 14, 2013 | 12:44 PM
bettyford's Avatar
Default broken ignition switch
so.... got Betty running ,the ignition switch may have been the trouble all along , if you have a first gen powerstroke truck and the switch seems alittle loose , change it before it gets stuck, here why ....to change/replace the key , all you need to do is push a little catch that's really easy to get to....with the key IN THE RUN POSITION....if the switch or key are broken the key wont go to the ON position and the little catch WILL NOT RELEASE! so your in deep doodoo....I wiggled the key for an hour or so, took off the shroud cover wiggled the steering for a bit while trying to turn the key, broke the protective cover off the switch ....lube , pried ,prayed some [more] and finally the key turned.... push the little button /catch and she pops right out....ps the new key/ignition comes in the 'ON' position , DONT turn it till its in the truck ignition hole.... og it wont go in ! hope this can help someone... if you know how to post this where it will be seen feel free.....ALOHA...
Old Oct 14, 2013 | 06:18 PM
Hyspeedz's Avatar
Hey bro, good luck to you. Your attitude is an inspiration. I hope you get 'er up and running OK.
Old Oct 14, 2013 | 08:46 PM
bettyford's Avatar
now on to the brakes.... the ol girl originaly took her rest /rust due to break problems, then dead batterys...so...fixed the brake booster vaccume pump. push the brake peddle and now there is power to the system, easy fix , one needs a puller for the pully but its easy to change, just three bolts....brake line leaking on passenger side , bought a real floor jack and stands at sears on sale. so ...up she goes, how do the calipers come off? guess we shall see...stay tuned....ALOHA
Old Oct 22, 2013 | 02:59 AM
bettyford's Avatar
betty runs, now she may even roll, did the front brakes, new calipers and pads, :argh ;now the abs light is on...bleed the brake lines/flushed and the peddle seems good, my son did the 123 hold and it seems like they are solid, but the ABS light worrys me...gonna get the core charge back and mat do the rears while im at it....I heard that there is a code to reset the ABS LIGHT , ? IDEAS? THANKS and ALOHA!
Cavnar
Sep 9, 2015 07:18 PM
doublehbar
13
Aug 9, 2015 12:35 AM
dandbmcc
Mar 14, 2015 11:05 PM
shawnecarter
Jan 7, 2015 05:54 AM
mpenny671
Oct 7, 2014 01:18 AM
