99 turbo and injector set up!
Old Oct 8, 2013 | 10:49 PM
duckslayer31's Avatar
Default 99 turbo and injector set up!
I've got a 99 24v. Its got a fresh built trans! 5 inch exhaust cold air intake, air dog lift pump. Im debating on what injectors and what turbo! I want 150hp injectors, I want to upgrade to a 58mm or 62mm what turbo and injectors should I get?
Old Oct 8, 2013 | 11:13 PM
H.R.D's Avatar
What do you plan on doing with the pickup?
I would go with an S362 with an A/R of .91 or 1.00 unless you don't mind lag and want top end then go with a higher A/R.
Old Oct 9, 2013 | 07:27 AM
I just want a truck at about 500 horse something to take to the drag strip and I've got a 28 foot enclosed trailer I haul quite a bit!
Old Oct 9, 2013 | 11:12 AM
jigabop's Avatar
7x.010 SAC injectors from DFI and a 62/71/14cm^2 turbo with a wiretap fueling box will do the trick
