Check engine light
Old Oct 8, 2013 | 05:16 PM
CumminsPower95's Avatar
Default Check engine light
I disconnected my MAPS sensor and put it right back the way it was but my check engine light stays on? Anything wrong or did it just shoot a code?
Old Oct 8, 2013 | 05:48 PM
Bryce's Avatar
If the engine was run with the map disconnected the engine light is probably just for the map sensor. You will have to hook it up to a scanner to clear the check engine light
Turn the key on, off, on, off, and then on again but do not start the engine. The trouble codes should display on your odometer
burndiesel
10
Feb 7, 2023 01:15 AM
Higgy
Jun 5, 2015 09:16 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
Rebel_redneck
Sep 29, 2014 11:05 AM
