92 f250 4x4 brakes
Old Sep 15, 2013 | 05:47 PM
knklbstr's Avatar
Default 92 f250 4x4 brakes
2 new mastercylinders,new powerbooster,new front calipers and hoses.bleed brakes good pedal,start truck pedal sinks slowly to floor.does not stop quickly. any ideads???also smokes when started and pulling a trailer
Old Sep 15, 2013 | 05:57 PM
4x4manonbroke's Avatar
did you bleed the rears first ?
from the top ..... right rear , left rear , right front , left front , .... of course check and top off in between ..... use a small clear hose ... place it on the bleeder screw ... pour fresh fluid in a decent size bottle ... place little hose in bottle with the tip under the fluid ( I start with about 1/4" of fluid to start) ... slowley have someone depress the pedal while you open the bleed screw ... the need to verify " Floor" then clos the bleed screw and the they need to verify " Up " ( do not pull up on the pedal you will be sorry ) ... do this at all 4 corners and you willl notice a difference ... if not Pm me and will go further...
also check to make sure your rear shoes are correctly adjusted .... should be just slightly dragging ( but just barley ) in the drum this is just about right .... any less then slight drag and you will have a mushy pedal until they adjust enough .... which can take a long time .... .... keep posted on results
Old Sep 15, 2013 | 10:56 PM
knklbstr's Avatar
did all that pedal is good and hard till u start the dang thing up then pedal slowly sinks to floor
Old Sep 16, 2013 | 09:43 PM
then your master cylinder is goin into bypass and is no good ... if you just bought it tis faulty ... I promice .......
jimmer4dat
Sep 10, 2015 01:07 AM
tim12valve
May 3, 2015 11:02 PM
SammyB
8
Apr 21, 2015 10:37 AM
pkcole
For Sale
Nov 20, 2014 08:11 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
