How much boost?
Old Apr 9, 2007 | 11:22 PM
Benjamin's Avatar
Bombardier
Default How much boost?
ok.... a few weeks... well about a month ago i installed my turbo and a few weeks ago.... a couple weeks after the turbo i installed the injectors and delivery valves.... i had a heck of a time with the new injectors keeping EGT's in check 1500*+ before going into 3rd.... so after some reading and thinking and looking at the bank account to see how much funds i had in there if i broke my truck i installed my boost elbow that i had in my HX..... in my HX it made ~42 psi without it i made a hair over 30..... so i figured that with this turbo making 41ish that this elbow should mahe around 50 or so..... mainly i was looking to clear up my haze and lower EGT's some...... so i installed it and made a quick drive around the block (it's a country 5 mile run or so) and got her up to opperating temp and once the thermostat cycled i layed into it...... EGT's got no higher than 1300* and boost felt real good @ ~53psi..... it felt so good on my second voyage out today it blew the intercooler boot off the intercooler on the driver side..... that's another thread..... any way.... how much boost before i'm really asking for my STOCK headgasket to go? it feels SOOOOO good and pulls so damn hard...... i don't want to back it down..... now keep in mind that i don't drive like that all the time..... just when i need to put a Powerstroke or a Duramax in their place...... i'm going to be on the rollers in a few weeks..... the 28th of this month to be exact and want to know how much boost have you guys ran and had good luck with? i know i'm pressing my luck but i don't want to come up with a wammie before i'm ready to pass.....
Old Apr 9, 2007 | 11:51 PM
Uncle Bubba's Avatar
At 40ish your already past the safe point. I won't go over 35, ever in my old truck. 35-38 is usually considered a high safe mark for the stock gasket.
Old Apr 10, 2007 | 05:53 AM
NOfullpullEL's Avatar
I would say you might run into turbo bearing failure at that boost level. I am pretty sure they are set at around 40 psi and if it was me I wouldn't go much past that. But that is me if you like it and think it feels safe run it.
Old Apr 10, 2007 | 10:16 PM
Benjamin's Avatar
Bombardier
everyone i've talked to, a Pro Street driver, and the owner of the business i bought the turbo from said the turbo would be safe running @ 50-55 psi due to it being a low drive pressure turbo and what not..... i've also been told that the stock gasket will blow somewhere between 40-50 so i guess i'm gonna find out how long it takes..... it takes at least 50 psi to clear up the smoke/ thick haze....... i'll be on the dyno on the 28th so if it last that long i'll be good..... i've already talked to Plillip Palmer of Stuckey Racing about doing this head for me when the gasket blows and he said he could make my truck wake up with all the mods i have done already...... and it dosen't help he's the current Pro Street Champ and already been 9.90 in the 1/4....... and he is a machinest by trade....... so i guess i'll go till she blows and that'll give me an excuese to get it to the machine shop to get "checked"..... that's all my wife needs to know.... the other stuff will have to be replaced cause it's "worn out".....
Old Apr 11, 2007 | 09:04 AM
Ratsun's Avatar
Keep your timing down and you shouldn't have to many troubles with the stock gasket for a while. That turbo at 50psi is safer than the HX35 at 40psi due to the the lower TIP produced. Boost doesnt kill HGs timing does, however in many cases the timing comes from excessive TIP from a over spooled turbo.
If you are really worried run a set of studs in and that will help.
I would say keep the timing below 17 degrees until you can get a set of o-rings in.
Old Apr 11, 2007 | 04:15 PM
Diesel Dummy's Avatar
Well i blew mine at 40 psi, but cummins claims they are good to 50 psi but you see how far i went(38K on truck), In stalled .10 over marine gasket and all is well so far.
Old Apr 11, 2007 | 04:24 PM
Whats your timing at? Had your 12V on a dyno lately?
Old Apr 11, 2007 | 06:24 PM
Benjamin's Avatar
Bombardier
my timing is stock.... 14.5* or whatever it is.... are you pointing these questions to me?
Old Apr 11, 2007 | 06:31 PM
Actually no..I was asking Ratsun....
Old Apr 11, 2007 | 06:43 PM
Benjamin's Avatar
Bombardier
ah i c
