Construction Equipment Discussion of Diesels Used for Construction - Bull Dozer's , Back Hoes , Skid Steers , Track Hoes , Dump Trucks
help with Cat d4 Fuel In Oil
Old Aug 19, 2013 | 02:14 PM
SmokiinRam's Avatar
Default help with Cat d4 Fuel In Oil
Ive got a 2005 Cat D4 With a Mitsubishi 5mvxl05.0aae and I noticed oil pressure dropped and found alot of diesel in the oil.Changed oil and filter ran for 15 minutes and its already 1/4" higher and smells of diesel. I dont know wether its the injector orings?or i/p shaft seal..theres not really any blow by or smoke runs fine just loses oil pressure. its also the mechanically injected not the oil pressure injected style
Old Aug 20, 2013 | 04:03 AM
97cummins's Avatar
Sounds like you have one or more injectors leaking fuel into the cylinders, you should also get a look at your rings.
Old Aug 20, 2013 | 11:22 AM
SmokiinRam's Avatar
Thats what i was also wondering but wouldn't I have more than normal blow by to have that much diesel getting past the rings?and some smoke? how to i determine where it coming from i don't want to pull the pump for it not to be the shaft seal either.I was thinking about trying some Uv dye in the fuel and pull the inspection plate in front of the i/p gear to see if its in there
Old Sep 4, 2013 | 03:05 PM
SmokiinRam's Avatar
well I rebuilt the injection pump an viola no more diesel getting into the engine oil and unit runs fine but i changed the oil and filter and the oil pressure is still reading almost zero at idle when it warms up,when cold its around 40psi...and i dont think it the gauge because the oil pressure light is also coming on and they each have their own sensors.someone mentioned theres a check valve in the oil cooler?
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
moneypitk5
Feb 12, 2015 11:01 AM
RLLBZ
Chevy/GMC Duramax 01-04 LB7
Jan 27, 2015 03:05 PM
bigredcummins
Jan 4, 2015 04:37 PM
