quadzilla adrenaline ?
Old Jul 31, 2013 | 09:10 AM
Crock's Avatar
Default quadzilla adrenaline ?
I took off a ADR 1001 box and pulse v2 controller off of a 2001 3500 and wondered what would be different besides the connections to put on my 99. I'm pretty good with wires was thinking I could make this work on my 99. Any thoughts would be appreciated. Thanks
bump
Old Jul 31, 2013 | 12:14 PM
jigabop's Avatar
map sensor connection is different, and iirc it was either inside the module itself, or inside the monitor (or both) there is a jumper you need to switch inside there and it is labeled 98-00, 01-02 for the positions. jumper position needs changed for boost to read properly and the module to fuel properly.
Old Jul 31, 2013 | 12:49 PM
Crock's Avatar
thanks I removed this for a guy that wanted is truck stock and he told me i could keep it for taking it off. For my info what does iirc stand for. Thanks for the info in advance
Old Jul 31, 2013 | 01:18 PM
jigabop's Avatar
"If I Recall Correctly" or "If I Remember Correctly"
Old Aug 1, 2013 | 11:32 AM
Crock's Avatar
i opened up the monitor and the module. there is no jumper that i saw in either is it a
wire you can move or is more like a switch
Old Aug 1, 2013 | 12:09 PM
jigabop's Avatar
they are header pins.
found a pic of it...
if it doesn't have a jumper like shown, then you need to put a jumper on it.
Old Aug 1, 2013 | 12:36 PM
Crock's Avatar
my board is different but i found a spot that has a jumper on it. doesn't say anything about 98-00 or 01-02
Old Aug 6, 2013 | 11:53 AM
Crock's Avatar
Installed the controler and got everything to work fine but i don't think my egt's are reading right. and my abs light is on. any ideas
KatiTrimmell
Jun 13, 2016 12:29 PM
dodge1998
Jun 13, 2016 12:25 PM
Baradium
Dec 14, 2014 05:04 PM
MAC4232
Oct 16, 2014 04:22 PM
estill03
For Sale
Oct 3, 2014 09:58 PM
