How about 618hp/900+TQ on 175's??
So a fella out in CA rolled 618hp/900+TQ using a built 68mm Pmax and 175/?? injectors. Not bad considering to get to 600+ in the past required 190 injectors or bigger. He modded/ported his intake manifold, has some supporting mods as well. I'll try and get the full details posted here.
If you don't mind buying modded cores sure they work. If you want a reliable you got to buy OEM injectors NIB that have been modded. For the costs I would stay with a smaller turbo and get a ported manifold. It's easier to go bigger on the turbo and injectors when you want.
The motor is a big air pump. Air has to get in and out. Make that path flow easier with more volume and you don't "need" a huge turbo and injectors to make a ton of power.
