99 horsepower?
Old Jul 16, 2013 | 11:01 PM
duckslayer31's Avatar
Default 99 horsepower?
I've got a 99 automatic. I've got 5 inch exhaust cold air intake and air dog lift pump allready! I'm looking to get about 400 HP. What mods do I need and especially what programmer? What's the best for the money?
Old Jul 18, 2013 | 09:59 PM
Al31031's Avatar
smarty maybe a fuel box on low settings your gonna want gauges for sure is the tranny built?
Old Jul 19, 2013 | 12:01 AM
luke46's Avatar
My truck puts 400 on the dyno to the ground but I have an nv4500. Setup ain't bad all around tows well drives well.
Old Jul 19, 2013 | 12:25 AM
I have gauges and yes tranny is built! I would like a moniter with the programmer! But I don't want to spend over 1000 dollars on it! Can I run a bully dog watch dog as moniter with the smarty? What size injectors? And would I need head studs if I ran stock turbo?
Old Jul 22, 2013 | 09:54 AM
blacksally's Avatar
I have gauges and a smarty , bully dog watch monitor I like em
Old Jul 22, 2013 | 09:57 AM
biged681985's Avatar
for 400 hp I would go with an egde juice with attitude and a set of 100hp injectors.
Old Jul 24, 2013 | 02:33 PM
Symon623's Avatar
X2, Your gonna want a lift pump to save the VP44, you will need to tap the pump to get the numbers you want.
I am skeptical you will get your numbers with the stock HX35, you will need to upgrade to a HE351 or a S300 in the 62/65 ballpark.
You wont need head studs unless you get over 45 PSI of boost...... You can re-torque the stock bolts and feel easy up to 45. Not likely you will see that much boost with and EJWA and 100's......
I have a II Phatshaft 62/65/14 for sale as it is too big for me when I am in towing mode. Spools too late....Towing is the kind of power I am after.
Old Jul 24, 2013 | 08:31 PM
Al31031's Avatar
i put 445 down on the dyno with an hx35 at 38lbs before most of my work
Old Jul 25, 2013 | 08:59 AM
on my 99 12v I layed down 454 hp 1156 with a hx35. of course I had enough fuel to spool a 66 with ease, but im a poor bastard.
on a buddys 01 dodge, he layed down 399hp with a edge juice with attitude 100s and everything else stock.
Aug 5, 2015 06:00 PM
12valve1998
Jun 29, 2015 07:32 PM
Chicle
6.0L Performance
May 19, 2015 05:53 PM
torque monsters diesel
Jan 30, 2015 09:38 AM
Jan 27, 2015 05:30 PM
