REBUILD P7100 BAD??
Old Jul 5, 2013 | 06:15 PM
osjr843's Avatar
Default REBUILD P7100 BAD??
i had my 95 p7100 pump rebuild but however, i can't make it run right. checked injectors...had two bad injectors. replaced all 6 with 5x12's. However, it still sounds like its missing. I checked timing and the pump is timed. first two cylinders are missing. is it just a bad rebuild job or I'm i not doing something right???
thanks,
doing something wrong*
Old Jul 5, 2013 | 06:52 PM
turbo2332's Avatar
if the IP is subject you can take the injector lines off the pump and turn it over. your gonna get fuel everywhere but fuel should shoot all over your hood from all 6. good lift pump pressure? you didnt piddle with delivery valves or anything after you got the pump back? reputable fuel shop rebuilt it? did you get a print out of cc's for the pump from the shop?
Old Jul 7, 2013 | 02:54 PM
osjr843's Avatar
so if it shoots fuel from all 6 does that mean the pump is working fine?? I replaced the life pump about 6 months ago but i haven't checked the pressure. I had diesel care from TN do the rebuilt didn't piddle anything nor did i get a cc's
Old Jul 7, 2013 | 06:15 PM
turbo2332's Avatar
not professionally but it will show you if the IP is pumping and creating pressure. you should put a gauge on the lift pump and see what you have.
CGwill
Apr 21, 2016 10:13 PM
|WYG|SS
Jul 4, 2015 08:31 AM
twm011
Feb 24, 2015 09:11 AM
Feb 5, 2015 12:10 AM
12vbomber
Nov 11, 2014 10:58 AM
