06 cummins temp gauge fluctuating
Old Jul 5, 2013 | 02:46 PM
dalton06's Avatar
Default 06 cummins temp gauge fluctuating
While its good and hot the dash gauge will drop to prob 160 then hang there for few seconds then shoot back up to around 200 then in a bit drop again and repeat. But my digital temp on my quadzilla rail pressure gauge stays right around 200-210. Think the thermostat or water pump messing up? It's prob been a year since they both were changed.
Old Jul 5, 2013 | 04:16 PM
RanchhandTCR's Avatar
Your should run pretty close to 190 while cruising you may have a thermostat issue or your low on coolant and are getting hot air pockets. The water pump should last longer than a year.
Old Jul 5, 2013 | 10:07 PM
dalton06's Avatar
Ok thanks. I'll get another thermostat and try it
JDurks2
16
Jun 7, 2015 08:57 PM
doodieroot
May 10, 2015 11:48 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
