2003 5.9 No Start
Old Jul 5, 2013 | 10:43 AM
Heavy Hauler 5.9's Avatar
Default 2003 5.9 No Start
I Am looking for some help on my 5.9.
I bought just bought this truck in not running condition, it spins over fine and will try to start on either.
It will not pull up any P codes and will not even display the P Code or Done but it does display C-codes AA. fuel gauge and Alt gauge are not registering and not turning on the lift pump relay ( pump works fine if I put power to it). I have replaced Batteries, instrument cluster, PCM and fuse box, cleaned grounds.
I plugged a scanner into it and it does read said there are no codes.
any ideas?
Old Jul 11, 2013 | 03:23 PM
biged681985's Avatar
sounds like the ecm is locked up.
Old Jul 11, 2013 | 04:05 PM
Thank you I am going to try a new one the end of next week.
That about all I have left.
irozchris
Mar 14, 2015 11:16 PM
ronstop
Feb 26, 2015 09:48 AM
texasd
5.9L CR Performance
8
Dec 20, 2014 07:39 PM
elkmaniac
Oct 29, 2014 07:01 PM
mpenny671
Oct 7, 2014 01:18 AM
