Running temperature, vibrations in the rear.
Old Jun 30, 2013 | 11:15 PM
198912ValveCummins's Avatar
Default Running temperature, vibrations in the rear.
I have a 1989 dodge ram D-350 single wheel long bed, 12 valve non inter-cooled of course, with the 3 speed auto trans, I can't find the spec for the running temp.
Also when I get over 45 mph I feel a vibration I think is in the rear, I changed the u joints, checked the diff fluid, rear wheel bearings, brakes blah blah etc etc and still does it. It got better after I did all that but it is still there. If anyone could help it would be appreciated thanks.
Old Jul 2, 2013 | 06:06 PM
blackduck's Avatar
Thermostats open around 181, anywhere between that and about 205 should be fine. Just running around without a load with everything in fair condition 185/195 would be reasonable figure.
The accuracy of your gauge may need checking if you have doubts
Old Jul 2, 2013 | 06:16 PM
I did hear that. But I was looking on a forum the other day and they said there's doesn't run over 170, 180 if towing. Of course that was an intercooled motor.. Which is why I was asking my truck in 110 degree weather with the a/c on it gets up to 192 and stays steady, cools down if anything... I have an aftermarket gauge to be 100% sure. Anyway thank you for the response greatly appreciated!
Old Sep 12, 2013 | 01:36 AM
Crazy Matt's Avatar
Have the driveline rebalanced. Ive seen alot of trucks that need it. Heck mine looked like a banana I guess when it was shortened for the 47rh.
Old Sep 18, 2015 | 03:34 PM
Texasboy's Avatar
If you have removed the rear wheels lately and didn't get them centered on the axle when reinstalled, it will vibrate.
Machinist
Jun 23, 2015 06:57 AM
robbyS
Apr 16, 2015 02:22 PM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
Oleoleson
Chevy/GMC Duramax 01-04 LB7
Mar 31, 2015 05:22 AM
carid
Jan 12, 2015 04:32 AM
