2006 F350 CC,SB,4X4,DIESEL ROLLING CHASSIS $2000
Old Jun 28, 2013 | 02:55 PM
BLACKSHEEP757's Avatar
Default 2006 F350 CC,SB,4X4,DIESEL ROLLING CHASSIS $2000
from rolled over truck with 63k miles.crewcab shortbed lariat.engine,trans,transfer case,front driveshaft,and steering box already removed and i will pull the cab and bed off and you can take whats left for $2000 or i will sell axles seperate for $1500 front and rear,3.73 gears, and then sell off the suspension parts
........ Will not sell any suspension parts untill axles are sold........frame has some damage from wreck but could probally be straightened
still have other parts available from this truck
transfer case,elec shift......$600
rear doors......$300 each
auto trans.... Good for core only... Came from an 07 truck that the one from this truck went in...... Burnt up,had no foward or reverse engagement........$150
power sliding rear window with motor and switch.... $150,you remove
factory 6 disc cd changer (couple of scratches on face) ..... $75
woodgrain dash bezel..... (some slight scratching as well)......$100
factory 20" alum wheels with 2 decent nitto tires and center caps.....$600
steering column with wheel (airbag blown).....$150
factory trailer brake controls..... $75
hydra boost with master cyl.... $100
vacumn pump......$50
injector wiring harness......$100
digital hvac control panel........ $100
ficm ...... $250
pcm .....$200
factory exhaust with converter and large,stainless tip..... $200
abs pump ....$75
steering fluid and windshield washer bottles ... $30 each
factory,class 5 reciever hitch ..... $100
headlights ...... $150 for the pair
factory air intake box ....$75
sunroof ...... $150 you remove
spare tire,275/70/18 on steel wheel,.. Never been used ....... $125
other misc that i may be forgetting?..... Just ask
....................... Call 757-642-3534......
Parts that are already gone are engine,(good) trans,left front door,complete interior,steering box,isnmt cluster,front shaft,
and other than the 2 rear doors and headlights,the rest of the body is trash
truck is located in va beach 23454.... Can ship most parts on your dime...... I take paypal plus the 3% fee that they charge to recieve the money
