Fuel leak diagnose
Old Jun 27, 2013 | 11:19 PM
DerekP129's Avatar
Default Fuel leak diagnose
Just from what I see it looks like where my fuel pre filter bolts on to the block is leaking fuel. Is this a common leak spot or is there somewhere above this that could leak such as a fuel line? Also what are most of the common spots for fuel leaks? When my truck is idling It doesn't seem to leak but as soon as I give it a good couple rev's and climb back under my truck to take a look it leaks like mad and also when I shut my truck off. Any help is greatly appreciated. Every week is another problem
Old Jun 28, 2013 | 03:20 AM
#cummapart's Avatar
I would let it dry and then start the truck and try to find where it is leaking. Give it a rev from under the hood if that speeds things up but be safe...I heard that stuff is flammable You probably just need to replace the o-ring on the housing you'll need something like this:
http://www.genosgarage.com/FLEETGUAR...info/3845400S/
Old Jul 4, 2013 | 11:53 PM
DerekP129's Avatar
It's not the pre filter itself leaking, but what I can see is it is the fuel line that comes directly into the top of the pre fuel filter housing. Does anyone know what is required to fix this?
Hoping someone can help me with this but maybe its even my lift pump?
Been doing a bit more of an analysis , it looks as if the #3 o ring on my lift pump is leaking, thats the one behind the primer button. Should I go about replacing this o ring or the pump itself?
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
cutthroatxxx
Dec 30, 2014 05:59 AM
Dec 5, 2014 08:30 AM
