Injector values
Old Jun 22, 2013 | 12:57 PM
puddlestomper's Avatar
Default Injector values
I sent my PCM off to get unlocked, got it back and now the #3 injector is reading 15.00 on the balance rate, and has a pulse width of.900. Before I sent it off everything was running fine, had a surge at 1900 rpm going down the highway. Now it is missing out at all rpm's, and the number 3 injector isn't firing. How can I chrck to besure this injector is bad before I tear into it? Seems like just changing the computer shouldn't do that. I don't believe in coincidence that the injector went bad between starts. No mods....
Old Jun 22, 2013 | 01:02 PM
When I accelerate the balance rates all go to zero. The average balance rate is -2 to +2 except number 3 which is 9.6
Old Jun 28, 2013 | 02:01 AM
2004LB7's Avatar
sounds like a clogged or stuck injector.
+15 is what it will be if no fuel is getting into the cylinder and the ECM is trying to increase the fuel to balance the idle.
anything more then +-4 in park and +-6 in drive is considered bad. the balance rates will only show when you are not moving and no throttle input, ie: while idling.
i have heard of some people, my self included, clearing stuck or clogged injectors by commanding max fuel psi for a short bit while idling.
doing the GM injector cleaning procedure wont hurt ether.
Old Jun 28, 2013 | 02:03 AM
My ECM came back damaged.
Old Jun 28, 2013 | 02:27 AM
2004LB7's Avatar
glad you figured it out. while it didn't seam likely i guess it is always a possibility.
Old Jun 28, 2013 | 07:10 AM
Yeah, I didn't think something like that would happen. Of course, I didn't think to write the serial number down as it didn't cross my mind that they might send me a different one. I'm really stinking mad about it. Paid them to ruin my computer.
