any ideas a little guidence would be greatly appreciated!!!
Old May 30, 2013 | 02:17 PM
MakitaBoy's Avatar
Default any ideas a little guidence would be greatly appreciated!!!
Alright it's gonna be a long story but I'm gonna shorten it as much as possible !
I've got a 06 megacab 90,000k I only drive it on the weekends. Out one weekend in it it started singing high tranny temp and just shut off it got worse and worse ( meaning it did it once then 5 mi later then 3 no then 1 no then 100 yrs) I got it home changed tranny fluid and filter took it out it did it again I shot pan cooler inlet andoutlet everything was nice and cool changed the governor sensor out tightened bands in tranny same issue. Sent my ecm off they found corridor transformers ?? Replaced them said it was good to go I had a mp8 and smarty stacked pulled the mp8 and put stock tune back in. Checked resistance on all grounds ( ecm and batterys) pulled harness from ecm to tranny cleaned all connections all wiring looked good adwell as connectors put a little dielectric grease in connectors still the same issue. It has gotten better but one day you can drive 20mi with no issues and the next day 1/2 a mile and it dies. It has a goerend tranny with a shift selector the dodge house unwired the shift selector and it still dies but doesn't flag high tranny temp now? But then again they also told me it was doing this bc of all the chips and programmers it has on it help me please!
Old May 30, 2013 | 03:10 PM
cummin_un_glued's Avatar
FormerVendor
Have you changed the trans temp sensor?
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old May 30, 2013 | 03:40 PM
MakitaBoy's Avatar
The way I understand it the governor sensor also takes the tranny temp?I was told it's like a processor? And I have changed that? I called the dodge house looking to buy one to put in and the guy told me I was after the governor sensor?
Old May 30, 2013 | 05:18 PM
Bryce's Avatar
I had the same thing happen with my 2004 3500 company truck minus the high trans temp. It didnt throw any codes and would die going down the road. It would always start right back up then do it again. It was the injection pump.
Old May 30, 2013 | 06:59 PM
MakitaBoy's Avatar
Hmm I would think it would throw a code for fuel psi if it was the inj pump? All the codes it's thrown have been loss of communication and a bunch of others I don't know exactly what they all were? A friend told me his brothers truck was doin the same thing but the whole dash would light up and it was bc his battery for the keyless entry was dead? I'm tryin that next!!!!
Old May 30, 2013 | 07:28 PM
FormerVendor
the FCA on the injection pump can stick and not throw a code. I've never seen a keyless entry battery cause any problems.
Old May 30, 2013 | 07:32 PM
MakitaBoy's Avatar
That's good too know! He said it was bc of the chip in the key?
Old May 31, 2013 | 11:45 AM
FormerVendor
Still wouldn't cause a problem while driving
Old May 31, 2013 | 12:13 PM
MakitaBoy's Avatar
I'm waitn for dodge to call me I had them put a different tech on it hopefully it's good news?
Old Jun 5, 2013 | 10:21 PM
MakitaBoy's Avatar
Dodge said its the fan clutch! I replaced about 20k ago ? Wasnt expectin that!
Boatman
Mar 20, 2015 10:00 AM
Duramax2323
Chevy/GMC Duramax 01-04 LB7
Mar 9, 2015 04:34 PM
