94 problems, help appreciated!
Old May 27, 2013 | 10:35 PM
Cumminsman911's Avatar
Default 94 problems, help appreciated!
I have a 94 2wd automatic cummins, and lately the speedometer and tachometer won't work, and at the same time the trans won't shift higher than 3rd gear, If you know of any solutions, it would be greatly appreciated.
Old May 28, 2013 | 12:45 AM
97cummins's Avatar
Do you have the fuse box also inside the engine bay? If you do i would look to see if you have a fuse or fuseable link burned out.
Old May 28, 2013 | 08:24 AM
olsmokey's Avatar
is the alternator charging properly? if not I could be an engine speed sensor issue or a pcm issue. I lost speedo, tach,tc lockup,overdrive and my charging system as a result of a bad pcm but another less expensive culprit is the engine speed sensor.
Old May 28, 2013 | 09:45 AM
glfredrick's Avatar
Most likely the speed sensor on the harmonic balancer on the engine. If it cannot read most of pcm functions stop. Clean and adjust stock unit first, then if no results replace. Expect bad parts unless you buy direct from Cummins.
Adjustment is critical.
Sent from my Galaxy Nexus using Tapatalk 2
Old Jun 14, 2013 | 08:46 PM
95taylor331's Avatar
Possible if the truck isn't charging and is losing voltage then the voltage regulator might be burned out , you can wire an external regulator in fairly easy, Im sure there is thread on here that tells how to do it if that's what it boils down to
Ohiocummins99
Jul 8, 2015 07:30 AM
Ol Goat
Jan 22, 2015 02:16 AM
Tucker126
Jan 2, 2015 08:09 AM
samscarfo
Dec 19, 2014 02:41 PM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
