47re filler tube leak?..
Old May 26, 2013 | 02:43 PM
gyayo2012's Avatar
Default 47re filler tube leak?..
Hey guys ive had this problem with leaking tran fluid so i went out and got a new cummins trans pan reusable gasket a new filter and refilled her with some fresh valvoline synthetic atf 4 well i came out side this morning and the damn thing is still leaking but it seems to be coming from the filler tube... is there an o-ring or something in there i dont understand why it would just start leaking now.. any ideas has anyone else had this issue idk if i should order a new tube or if i should just gooup it uo with some jbweld or something.. any ideas?!
Thanks
Old May 26, 2013 | 09:21 PM
tiremann9669's Avatar
Most filler tubes have an o ring although I've never looked at one from a Cummins truck.
Old May 27, 2013 | 06:38 AM
BBD Tech Support's Avatar
Yours should have a oring or (rubber sock about 3/4 to 1" long) looking seal on the filler tube. depends on if it has updated filler tube or not.
Old May 28, 2013 | 08:41 PM
4x4manonbroke's Avatar
it will have an O-ring about and inch from the bottom of the dipstick/filler tube ... and what ever ya do do not JB it in ... if you have to pull trans you will be really sorry .....
Old May 30, 2013 | 09:11 PM
gyayo2012's Avatar
been real busy havent had any time to jump on the computer but that same day i went out and pulled the stick the o-ring lookd fine but i replaced it with a slightly thiker one and boom no more leak!! i knew i should have lookd there first before i went out and spent 100 bux, but w/e ive been running her pretty hard for a few years now so she needed a good drive train tune up!! i wasnt really going to jb weld it just some bs talk from being agitated! Thanks for the input fellas always very much apreciated !!
Old May 31, 2013 | 09:46 PM
... np .... glad its fixed
LariatOutlawGirl
Sep 1, 2015 02:15 AM
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
