2013 Urea Proublems?
Old May 23, 2013 | 06:49 PM
Dodge325hp's Avatar
Default 2013 Urea Proublems?
Im looking at ordering a 3500 with Aison tranny and don't plane on doing any deleats. just wondering if any one is have any proublems and what kind of fuel milage? Thanks for any ones input on the 13"s
Old May 23, 2013 | 07:31 PM
RanchhandTCR's Avatar
Besides a realy expensive fluid, and not readlily found, its a big thing to worry about when it comes to the DEF(Diesel Emission Fluid). Not to mention these trucks now do what is called a Regeneration. Since 2007 diesel come with a DPF(Diesel Particulant Filter) Which catches soot from the exhaust and when it fills up, you got to stop and let the truck burn your diesel and time while it burns out the soot. Just something to consider.
Manufactures use DEF Now so they can get more power and mileage out of them, the power is on the good side but the mileage sucks. near 12 mpg
Old May 23, 2013 | 07:56 PM
Buffinator's Avatar
You might as well embrace it. And it seems that I can find the stuff almost every place I stop for fuel now. Guess that just means it's nice driving by 2 full service truck stops on the way to and from work now. You can go quite awhile without filling up that tank. My 2500 is getting 18 mpg in its first 1000 miles so far. Obviously, you can plan on less
Old May 24, 2013 | 07:10 AM
Dodge325hp's Avatar
I don't think you will use much urea unless your pulling hard from what others have told me and you can buy it in bulk a lot cheaper at some truck parts dealers and Implement dealers. 18 not too bad for not even be broke yet it should get better. Thanks
Old May 24, 2013 | 01:43 PM
DslDeamon's Avatar
run a 13 3500 reg cab DRW with DEF on the farm havent had any problems with it yet but only has 5k on it now but over 450 hrs on it do more pto work with it then running down the road but with it it appers to be more alive compared to my 11 "both manual trannys and same gear ratio" witch just has the dpf when im pulling trailers mpg better but not great 14-16 highway empty best ive seen but averge around 12 hope this helps you
Old Jun 5, 2013 | 01:59 PM
tjbaze's Avatar
Just bit the bullet and bought a 2012 2500 4x Laramie Longhorn to replace my 02 2500 SLT. Looks like I have a lot of work to do...Nice truck! have put all of 300 miles on it...
Old Jun 6, 2013 | 09:33 PM
coors_man_2005's Avatar
If it was me i wouldnt buy any new diesel without plans of deletes unless i was going to trade the truck yearly all the emissions do is ruin a perfect engine and wear them out sooner then they really should
Old Jun 10, 2013 | 02:43 PM
tjbaze's Avatar
Default Re 2012 2500
My intent was to get a new truck with all the creature features & not have the urea injection.
There is plenty of info on deletes and agreed the newer the truck the more involved it gets. Thus far the comfort and power is so superior to my 02 that's its unreal . I haven't had time to check egt's etc , I"m sure their high. For right now I"m going to read up and plan my mods ...
Old Jun 12, 2013 | 10:07 AM
jam20ster's Avatar
I just purchased 2013 Ram 2500 6.7 Laramie 4x4 Mega Cab. At first i wasnt too thrilled about the urea, but is seems to readily available were i live. My experience which is only a 127 miles is 22 mpg highway. Im sure not going to complain about that. Also my dealership said oil changes are only $59, which is much cheaper than my f250 6.0 was.
Old Jun 12, 2013 | 04:40 PM
tjbaze's Avatar
Default Re 2013 mega
That's good news, I had no idea that there was that much of a mileage boost between 2012 and 2013. You will really enjoy that truck...
I am amazed at the ride comfort and power ....still looking for excuses to go somewhere.
Have put around 600 miles on mine...that new 6 speed automatic is sweet , unusual that it shows a higher payload towing capacity than the manual.
Weird
