Injectors 12 Valve Cummins
Old May 23, 2013 | 01:25 AM
Dodge12Valve's Avatar
Default Injectors 12 Valve Cummins
Hey i have 12 valve Cummins 1997 and i took my stock injectors out and replaces them with DDP injectors my MPG dropped about 200 so i backed my star wheel off and my stock fuel plate is slid full forward i got them pop tested and they were fine by BD diesel and said they spray pattern is 155 not 145 so is that fine or bad HELPP there stage 1 injectors so 50HP and when the truck is in idle and i put my foot on the throttle all the way down quickly smoke comes out whitish blueish and pops Timing may be out ???
Old May 23, 2013 | 07:58 AM
olsmokey's Avatar
the truck pops when you floor it at and idle? thats called breaking down. if the truck breaks down at or before about 1250-1300 rpm is needs to be timed. some timing adjustment may solve all your problems
Old May 23, 2013 | 11:22 AM
cummins Pride's Avatar
what did you torque your injectors too
Old May 23, 2013 | 11:28 PM
turbo2332's Avatar
also could be low fuel pressure. possible a crapped out OFV...
Old May 25, 2013 | 09:57 AM
jkidd's Avatar
sounds like you have the dirtier 4 hole marine injectors rated at 300-330hp. They sell new for about $360
don't time above 16-16.5* and you will be fine.
check out our DAP injectors if you want some with the correct spray pattern. We have 5 and 7 hole options for the 12v
gh0stman
Price Quote - Request A Price
Sep 9, 2015 12:12 PM
mrh1282
For Sale
Jul 20, 2015 04:27 PM
Zachbishop
Mar 5, 2015 09:50 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
