96 missing
Old May 21, 2013 | 07:27 PM
eddie7644's Avatar
Default 96 missing
I got a 96 and it has a miss. When its idling its rough but when you take off you cant feel it miss at all but can here it popping out of exhaust. i keep checking for air in the system and i cant get any. Things that have been done so far.....new injectors, fuel filter, sender, injection pump out of one that was running before totalled, #6 fuel plate, timing advanced to 16.5. retourqed head bolts. My fuel pressure gauge at idle shows 17 psi. It is really rough when you put it in gear at idle and sometimes it stalls. Also need to use pedal to start or it will just crank.
Old May 23, 2013 | 11:43 PM
turbo2332's Avatar
it pops out of the exhaust?
that says open or burn valve to me. have you done a leak down test?
or is it like a stumbling miss? any white smoke, which could lead one to a bad injector or slipped/retarded timing.
Old May 24, 2013 | 08:01 AM
eddie7644's Avatar
Its like a stumble miss sounds like air ssucing thru exhaust and there is no smoke
Old May 24, 2013 | 08:25 AM
mysterync's Avatar
What happens when you crack one injector at a time while running
Old May 24, 2013 | 08:28 AM
eddie7644's Avatar
I get a very short first of air bubbles then spitting fuel only happens with like three injectors
Old May 24, 2013 | 12:53 PM
turbo2332's Avatar
possible leaky fuel heater? any damp fuel lines pre lift pump. this is where you will pick up air in the system and have no real leak.
Old May 24, 2013 | 12:55 PM
eddie7644's Avatar
I deleted the fuel heater but im leaning to lift punp
Old May 24, 2013 | 01:37 PM
turbo2332's Avatar
i wouldn't necessarily at 17psi @ idle. what is your idle speed set at?
Old May 24, 2013 | 01:39 PM
eddie7644's Avatar
Old May 24, 2013 | 01:43 PM
turbo2332's Avatar
high but wouldn't give you the stall issue. hmmmm
did this just happen or right after a certain mod?
