please help 1997 cummins wont start
Old May 18, 2013 | 06:37 AM
pro fire guy's Avatar
Default please help 1997 cummins wont start
I need your help heres what happened i have a 1997 12 valve stock with standard transmission i fueled up drove about 10 miles suddenly truck lost power when up shifting stopped truck quit tried to restart only way was to hold on floor no power appears to be flooding lots of smoke now it wont start how and what do i check i loosed injector lines and am getting fuel there please help i need my cummins back
Old May 18, 2013 | 07:02 AM
1999stroker's Avatar
Check your fuel filter maybe its clogged?
Sent from my DROID RAZR
Old May 18, 2013 | 07:26 AM
actually i just changed the fuel filter about 200 miles ago i was wondering about the computer is there a way to check it thanks any ideas
where i get my fuel there are lots of trucks fueling and ive never had a problem with there fuel not sure what the problem is the computer on my 95 is different so i cant try it thanks
Last edited by pro fire guy; May 18, 2013 at 07:26 AM. Reason: Automerged Doublepost
Old May 18, 2013 | 09:06 AM
mysterync's Avatar
The computer has nothing to do with how the truck runs.
Check your shutoff solenoid and make sure its all the way up. There are some basic checks that can be recommended but its a much better idea to take the truck to a shop with a qualified tech, and allow them to diagnose it.
Old May 18, 2013 | 09:09 AM
mysterync's Avatar
With the little information you have posted I see three possible issues.
1: if the truck is running but makes no power a blown intercooler boot.
2: slipped injection timing.
3: cracked injector or failed injector.
Old May 18, 2013 | 10:25 AM
we removed the shut off solenoid had a problem with it before its ok truck doesnt run or start right now next step is to check injector pump timming we had it off a while back for rocker gasket change thanks any other ideas
Old May 18, 2013 | 10:28 AM
mysterync's Avatar
I vote timing has slipped.
Old Jun 14, 2013 | 09:35 PM
95taylor331's Avatar
x2....
Old Jun 14, 2013 | 11:52 PM
4x4manonbroke's Avatar
thats what happened to me ...... really sucks ...
Old Jun 16, 2013 | 07:27 AM
The pump timing or the rocker cover gasket the rocker cover gaskets a big job I ordered jobber gaskets cork junk never put them in went to cummins got the rubber ones well worth the money not a job you want to do for fun still haven't had time to check pump timing I hope that's the problem thanks for the help
