best place for trans temp sensor?
Old May 17, 2013 | 12:38 AM
bestrada11's Avatar
Default best place for trans temp sensor?
so what is the absolute best spot for a trans oil temp sensor? I know it cant be a test port so I was thinking a welded bung on the pan??
Old May 17, 2013 | 01:09 AM
joebob3093's Avatar
Moderator
the test port
Old May 18, 2013 | 12:50 AM
bestrada11's Avatar
wouldn't the fluid introduced to the sensor at the test port be a "stagnant" reading as its not the actual fluid supply being circulated thru the trans????
Old May 18, 2013 | 03:11 AM
joebob3093's Avatar
Moderator
Nope, but since you know it can't be the right place for it put it in the pan. Drain your fluid just to change a sensor. Hope yours never goes out because it will be a PITA
Old May 18, 2013 | 11:38 AM
bestrada11's Avatar
Hey calm down lady... I'm trying to get a discussion going because I hear both ways from 3 differant diesel mechanics that have been doing it for over 15 years so thats one point they made is the fluid not circulating and giving a delayed reading as the tranny burns up...
Old May 18, 2013 | 03:52 PM
Bigg Redd's Avatar
Most aftermarket trans pans have a bung already welded if steel, or machined if aluminum, on one of the sides, so it must be ok to install there. I know there is a concern about "delayed true reading", but really, has it been an issue?? You can always tee into one of your trans lines (the hotter one) for a more "accurate reading."
Old May 18, 2013 | 10:25 PM
joebob3093's Avatar
Moderator
If its a discussion why come on here saying it can't be the test port? Thousands of people do it that way and are just fine. If you want to go make it a pain in the *** and reinvent the wheel go right ahead
Old May 19, 2013 | 12:10 AM
bestrada11's Avatar
big red I like that idea I didn't even think about that that is exactly what im gonna do I thank you for at least entertaining my concern about the test ports. I mean its not completely out of reason to think that the test port would give even a small accuracy error. I mean if good enough will do than why not just rely on the factory gauge on the cluster????? because its not ideal and ideal is what im after. so again thanks for taking the time and not taking my saying that " it cant" be the test port as the word of god!! man the tranny line how obvious how I didn't think of that is embarrassing!!!
Old May 20, 2013 | 09:27 AM
geddy's uncle's Avatar
Outbound (hot, naturally) trans line. way-back-when, mine was done by cutting a short piece out of the line, and putting the sensor between the splice connectors. It always had drippage. I guess the combination of heat, pressure, and a reluctance (paranoia?) of overtorquing the aluminum tubing and brass fittings was the cause on that. HOWEVER, hindsight being what it is, it seems like a better approach would have been to replace the fitting right at the housing with a nice "tee", and then adjust the tubing's geometry to fit. This was on my Dodge, and there was a nice amount of empty-space clearance. I don't know if you've got that amount of space under your truck.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
doodieroot
May 10, 2015 11:48 PM
robbyS
Apr 16, 2015 02:22 PM
mule97
Dec 12, 2014 05:05 AM
