O/D button acting up
Old May 12, 2013 | 02:10 AM
DerekP129's Avatar
Default O/D button acting up
Has anyone ever had or heard of the overdrive off button turning on by itself? I have had it happen 3 times now over the past 6 months of owning this truck. What could it be caused by and how can I fix it?
Old May 12, 2013 | 11:16 AM
geddy's uncle's Avatar
could just be dirty inside. take the button apart. (easy; the outer ring is just a piece of plastic with flexible barbs to retain it, just pry it off and it'll go back on later) the contacts are two pieces of copper (gold-plated, maybe?) zig-zagged across a plastic disc. The switching material is a piece of conductive rubber on the button. Clean the disc, clean the little "rrrrrrrrubbah biskIT!!!!" (I had to do it) with some rubbing alcohol and reassemble. The buttons inside your alarm remote, and under your computer's keyboard are the same way. CLEAN'EM ALL!
Old May 12, 2013 | 12:22 PM
DerekP129's Avatar
Thank you for the reply I will give this a try today
Old May 12, 2013 | 10:33 PM
detroitdiesel idi's Avatar
servo itself in the trans could be sticking
Feb 20, 2015 09:40 AM
David220
6.9L & 7.3L Performance
Feb 11, 2015 04:29 AM
wood2turn
Chevy/GMC Duramax 04.5-05 LLY
Jan 1, 2015 07:28 PM
justinsbeck
Nov 21, 2014 11:53 AM
longcarbine
Nov 13, 2014 11:33 PM
