Need advice on Turbos
Old May 9, 2013 | 12:18 PM
MechanicalDiesel's Avatar
Default Need advice on Turbos
I am currently looking to upgrade my turbo , but I am confused on which one to get.
Im looking at the following 3 as of now but am open to suggestions.
Super B Special
Aurora 4000
Silver Bullet 64
Which would be best for me? I use my truck for fun and as a backup/toy. I dont tow much if at all, its mostly for fun and as a reliable back up DD.
Future upgrades will be Headstuds, delivery valves, possibly bigger injectors 5x.014 or
5x.016s, hopefully soon I will bench/turn up my P-pump.
Looking for between 425-550hp maybe 600 in the future.
Old May 9, 2013 | 01:26 PM
cummins Pride's Avatar
super B special the aurora 4000 would not be bad
i read if you were ever going to work with the truck or tow 10,000 pounds they were not sure if the 4000 would cut it they would recamend the super b special and the 4000 is 5 percent more money that the super b special idk about the silver bullit 65
Last edited by cummins Pride; May 9, 2013 at 01:26 PM. Reason: Automerged Doublepost
Old May 9, 2013 | 02:21 PM
94 12valve's Avatar
out of thoes three super b special
Old May 10, 2013 | 08:10 AM
Would my current 5x.013 injectors be good enough for the super b special? or would i need to go bigger?
Old May 10, 2013 | 01:15 PM
they would be ok but you can run way bigger with that turbo 5x.013 they consider 60hp injectors
Old May 10, 2013 | 01:17 PM
94 12valve's Avatar
should do just fine to start could always go bigger if you like.don't be affraid to run some more timing either,add a rack cap, make sure you have good fuel pressure to the pump and you will have a pretty fun street truck
Old May 10, 2013 | 01:42 PM
jup
Old May 10, 2013 | 02:58 PM
OK, before I bump up my timing I gotta get some headstuds.
I should be good on fuel pressure got a airdog 2 165.
Ill give it a try and if I find myself wanting more ill go to 5x.016s
What would be good for timing?
Old May 10, 2013 | 03:15 PM
94 12valve's Avatar
I always had the best results with 22* for the street
Old May 10, 2013 | 04:31 PM
CR9712v's Avatar
can you put a HE451Ve on a 12 valve??
