Glow plug relay
Old May 4, 2013 | 01:01 PM
nmorrison's Avatar
Default Glow plug relay
Would a bad glow plug relay cause a truck not to start at all or cause it to hard start??
Old May 7, 2013 | 08:46 PM
racer55's Avatar
Sure check for power at the glow plugs-these need glow help even in warm weather.
Old May 7, 2013 | 08:53 PM
nmorrison's Avatar
I drove the truck Friday night. Got in it Saturday mornings, wouldn't start. I tried a few things and nothing. Hooked the battery charger up for a couple hours. Messed with it some more. Finally I said what the heck and open the bleeder on top of the fuel filter cap, turned over a couple times and started right up. Had to open it 2 more times Saturday to get it to start. Bad ip, leaking injectors? There is no cracks anywhere in any lines, nothing is wet.
Old May 7, 2013 | 09:15 PM
racer55's Avatar
Check closer under the filter housing-sounds like fuel is leaking from the water in fuel sensor or fuel heater o-rings in the filter housing letting air in.
Leaks between the LP and the fuel level in the tank tend not to leak fuel but suck air since they are under suction rather than pressure.
Metz1234
Mar 3, 2016 10:20 PM
Texasthb
Mar 4, 2015 08:20 AM
Kooper
Jan 11, 2015 08:52 PM
norcal6.5
Dec 7, 2014 07:04 PM
7.3lfordguy
Oct 16, 2014 10:26 PM
