4x4 issue?
Old Apr 28, 2013 | 10:13 AM
first-gen-tough's Avatar
Default 4x4 issue?
2wd works good. but when im in 2wd my front drive shaft spins. My transfer case locks in and unlocks with my 4x4 on the floor but the shaft always spins. Im not in 4x4 all the time just the shaft spins and seems to be locked in in just the axle and not my transfer case. Not sure if I have a vacuum problem in my axle?? my transfer case works fine my guess its in my axle. Any ideas????
Old Apr 28, 2013 | 11:32 PM
sweetv8s10's Avatar
The axle on the drivers side turns all the time and it will turn the drive shaft as well.
Old Apr 29, 2013 | 06:27 AM
even in 2wd? My truck does but not my buddies. same year and his 4x4 works too
Old Apr 29, 2013 | 09:21 PM
moneypitk5's Avatar
as long as your drivers tire is on the ground, it will spin when you are moving. if your buddys doesnt, then he either has a hub kit or there is something dreadfully wrong in his front end..
Old May 1, 2013 | 04:41 PM
All the tires spin when on the ground and moving ... When im in 2wd my front drive shaft spins when im driving. on my buddies his drive shaft doesnt spin when he drives.
Old May 1, 2013 | 04:58 PM
moneypitk5's Avatar
Weird. sounds like something is wrong with your truck.
Your "issue" is that you dont have a clue how a full time front end works. we have told you why your drive line spins in 2wd several times.
Now, if you still cant seem to get it, either jack up your front end and learn something, or sell the truck and get something more manageable with your obviously limited desire to understand how things work.
Old May 2, 2013 | 03:19 PM
1993firstgennewbie's Avatar
your truck is fine
DIESELDENT
For Sale
Dec 19, 2014 06:53 PM
Dec 7, 2014 11:20 AM
mabr0503
Nov 27, 2014 01:36 PM
Oct 23, 2014 08:10 AM
Sculpturesylvan
Oct 18, 2014 10:19 PM
