Blue smoke at idle
Old Apr 27, 2013 | 05:37 PM
JPope's Avatar
Default Blue smoke at idle
I just bought an 02 duramax 2500 hd. I did research and made sure injectors had been replaced before i bought it but now it is smoking. Previous owner said it had been doing it for as long as he owned it. Injectors were replace at 70000 and i bought it at 188000. I took it to a shop and had it checked out, mechanic said that number 3 was slightly jumping but not enough to make it smoke like that. The smoke smelled like fuel until two days ago now it is rank, any suggestions? Ive been researching on replacing injectors and wondering if it is better to replace all eight or if it is ok to just replace one side. Also were is the best place to get injectors?
Also the smoke went from just building up at idle to smoking all the time. From what ive read the injectors are need to be replaced but dont understand why the smoke changed and what could be going on with that.
Old May 3, 2013 | 01:03 AM
2004LB7's Avatar
Typical injector issues.
You can replace jest one without problems but it take so much work to get at them that most will replace the others. History says if one is out the others are not far behind.
With its history I would run an aftermarket suplementary filter. I would also try the GM injector cleaning procedure
Old May 3, 2013 | 02:12 PM
JPope's Avatar
What is the procedure or where can I find that info? Thanks for your help!
Old May 3, 2013 | 02:21 PM
MillerBoyzDiesel's Avatar
Not really a gm thing but they use it. BG and other companies have an injector cleaning chemical and a contraption that hooks into your fuel lines and runs the chemical through the injectors while truck is running. Claims to drop balance rates a few points. BG rep mentioned one truck that was pretty bad that cleaned up after three consecutive cleanings. The cleaner will not fix damaged seats from poor filtration tho. It might be worth a try but, no guarantee that it will work.
Old May 3, 2013 | 02:50 PM
2004LB7's Avatar
Old May 4, 2013 | 08:55 AM
JPope's Avatar
Thank you gentlemen think i will look into doing this before i replace injectors. Just need to find cleaner and contraption. Thanks again!!!
If I do end up replacing the injectors where is the best place to buy, most cost effective and best injector.
Old May 5, 2013 | 01:27 AM
2004LB7's Avatar
Lincoln diesel gets my vote
Old May 6, 2013 | 07:59 AM
^ Lincoln seems do be good deal.
Jmrobinson
11
Aug 21, 2015 09:54 PM
tim12valve
Jun 16, 2015 09:59 AM
gagemotors
Jun 9, 2015 04:24 AM
honda89
Dec 27, 2014 06:19 PM
lil red
Oct 10, 2014 09:03 AM
