Burnt valve?
Old Apr 25, 2013 | 09:53 AM
mmitchell's Avatar
Default Burnt valve?
I bought an 01silverado duramax for a little bit of a project truck/ something fun to drive, was told needed two injectors turns out lost compression in cylinder two, no fuel in oil and no oil/radiator mixture but smokes pretty good. Does this sound like a burnt valve? I replaced the injectors. when the glow plug was pulled out to do compression check the tip was burnt off. So it definitely got hot. just looking for some guidance before I start tearing it apart.
Old Apr 25, 2013 | 10:51 AM
MillerBoyzDiesel's Avatar
Usually the tips break off and take out the cylinder. Youll see what all you need once you get the head off.
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
Baradium
Mar 9, 2015 07:15 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
