egts
Old Apr 22, 2013 | 10:33 PM
cummins Pride's Avatar
Default egts
hey guy i have a 1996 12v and i have a 5in mbrp pipe running only 28psi of boost stage 2 afe intake after market injectors (big) and my afc starwheel wide open and when im cruising my pyromter can hit 1000 degrees just cruisin at 2 psi of boot on freeway any way i can lower the egts i was thinking about aftermarket exaust manifold what you guys think
Old Apr 22, 2013 | 11:00 PM
RanchhandTCR's Avatar
Adjust timing, and maybe back down the start wheel. also where is your pryo at is it 3/4 to one side right smack dab in the middle or behind the turbo.
Unburnt fuel eguals more heat, tune it better and have it burn all the fuel so it will run cooler. How big of injectors do you have? also because if you dont have the proper timing, air, those injectors are just dumping fuel... Hope they are no more than 90 horse.
Old Apr 22, 2013 | 11:30 PM
the timing is stock from factory injector came with the truck i had them ebuild all we could find out about them was that they pop off at 360 and i think there bigger thsn 40hp forsure once i saw 40hp injectors pop at 310 or 290 i thik it was
Old Apr 23, 2013 | 11:08 AM
94 12valve's Avatar
360 is way too high of a pop pressure 260 is prob what there set at as for running cooler you need to tune your afc and not have it set as loose as it can.
Old Apr 23, 2013 | 11:14 AM
ok will do thank you guys and what would you think of a aftermarket exaust manifold on a stock turbo
Old Apr 23, 2013 | 11:22 AM
94 12valve's Avatar
not worth it
Old Apr 23, 2013 | 11:26 AM
alright thanks for the help
Old Apr 23, 2013 | 07:08 PM
I have one because I had my last one crack. Notice slightly faster boost but thats it..
Old Apr 23, 2013 | 11:06 PM
what about the egts what did they seem to be like
Old Apr 24, 2013 | 01:25 PM
Sat the same, what made a difference was straigh pipeing it they dropped 100 degrees at 65 mph
