turbo master
Old Apr 22, 2013 | 09:27 PM
cmtoutlaw34's Avatar
Default turbo master
i have recently ordered the turbo master from health diesel and want to know if anyone knows where to go to find a egr delete so i can complete rid the truck of the vacuum pump i have a 1996 k1500 6.5 also what do i do with all the vacuum lines and solenoids thanks for the imput
Old Apr 23, 2013 | 11:38 AM
racer55's Avatar
Solenoids and baro sensor must remain connected unless you get a reflashed chip that has those functions removed,otherwise all lines can be removed IIRC,could be wrong about the baro sensor function though-most get a performance chip or a F vin chip.
If running a turbo master a boost gauge should be used and an EGT gauge is always a good idea.
Most folks use a frost plug that fits the tower in the lower intake for EGR delete and leave the EGR installed or get an F vin upper intake,or get a complete F vin intake and use gaskets with block off plates.
Old Apr 23, 2013 | 02:14 PM
with a turbo master in place can i remove my vaccum pump since im going to do a egr delete or is there other things that it runs also what is a frost plug
Old Apr 23, 2013 | 02:50 PM
racer55's Avatar
The vac system is interconnected with the barometric sensor,the EGR and the boost system-a custom ECM tune can be done to add power and work properly with the turbomaster and is a common upgrade-Heath,Kennedy and KOJO as well as a multi tune system from Buddy Tunes can be had reasonable.
A frost plug also known as a core plug is what is used to seal the holes in the side of blocks and heads where the sand mold is held in place when they are cast at the foundry.
Old Apr 23, 2013 | 03:17 PM
where can i find a frost plug
Old Apr 23, 2013 | 03:34 PM
racer55's Avatar
Any auto parts store or automotive machine shop-they are sometimes called expansion plugs also:
eg:expansion core plugs | eBay
http://www.ebay.com/sch/eBay-Motors-...nkw=frost+plug
http://www.ebay.com/sch/i.html?_odkw...+plug&_sacat=0
You need to know the diameter of the hole you are trying to fill though.
Old Apr 26, 2013 | 07:59 PM
so a frost plug looks just like a freeze plug that you would put into a motor if you were rebuilding it
Old Apr 27, 2013 | 11:03 AM
racer55's Avatar
Yes same exact thing-the real name for them is core plugs.
avatardvr
18
Aug 8, 2019 12:38 AM
klein444
Feb 27, 2015 01:53 PM
n2brk
Feb 21, 2015 09:05 AM
TurboBoy6.5
Dec 7, 2014 07:13 PM
GreenDieselF
Oct 20, 2014 02:05 PM
