changing injectors
Old Apr 21, 2013 | 05:56 PM
cmtoutlaw34's Avatar
Default changing injectors
is there a easier way to change the injectors on the passenger side other than taking off the upper intake and removing the passenger side exhaust maniford or is that the only way also my truck is starting to have some very bad blow by and using oil is there anything i can do for that thanks for the help
Old Apr 21, 2013 | 06:04 PM
detroitdiesel idi's Avatar
No turbo and exhaust manifold will have too be removed. replace glow plugs while your in there as well. as for blow by soak your cdr canister in diesel to clean it.its the part on your truck with decal that says notice this end up.but most likely blow by is from hard life and has worn piston rings and or cylinder walls
Old Apr 22, 2013 | 09:32 PM
so with the possible worn pistion rings and or cylinder walls so how long does the truck have left to live it has 272,000 miles on it now will it last another year till i can get the 10,000 to rebuild it or will it die sooner
Old Apr 23, 2013 | 11:42 AM
racer55's Avatar
Many people get used low mileage military takeouts from Teds Trucks and Stuff for much less money than a rebuild and get a better engine in long run-navistar blocks and heads are commonly sent.
Old Apr 23, 2013 | 07:19 PM
10,000$ ? whered you get that quote at? i rebuild engines all the time and parts to rebuild a 6.5 cost me only 1100 so after labor n paint n remove and install i charge about 2000$ itll most likely last another year though
Old Apr 23, 2013 | 07:27 PM
racer55's Avatar
New from GM or GEP is around $11,000.
Old Apr 23, 2013 | 07:29 PM
damn rippoff..fer tht u midas well get a dirtymax computer on wheels
Old Apr 24, 2013 | 08:52 PM
i have called a few places and they all quote me around 8-9500 to rebuild that includes all the machine work magnfluxing the block and heads and rebuilding the heads and all new internal and external parts if i could find a place to do it for 2000 around here i would have it in the shop tomorrow i love my truck just hoping it dont die on me till i can get it rebuilt cause i need it to pull my camper and show car
Old Apr 24, 2013 | 09:15 PM
racer55's Avatar
Those prices are absurd.
You should end up with a brand new block,heads,steel crank,rods,valves,cam,lifters,pistons,connecting rods,main girdle ect.ect.ect for that price.
Contact Peninsular Diesel in Michigan for a long block price plus any other hardware you think you need.
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
