gauge cluster not working
Old Apr 19, 2013 | 11:08 AM
jonesy9310's Avatar
Default gauge cluster not working
Tachometer speedometer alternator voltage and coolant temperature are not working but fuel and oil pressure are still woking
Anyone? Please
Last edited by jonesy9310; Apr 19, 2013 at 11:08 AM. Reason: Automerged Doublepost
Old Apr 20, 2013 | 04:03 AM
97cummins's Avatar
Well i'm looking at my book for your truck,mine is just 3 years older.
As for your tach,the book says it's tied in with your pcm(powertrain control module)
as for the speedo,your vehicle speed sensor may have gone out.
As for the alternator,i would also lok at the pcm.
It's just wierd that those four are the only ones out, take a look at the fuse panel in the engine compartment.You may have some fuses out,or fusable links out.
Old Apr 20, 2013 | 12:40 PM
jonesy9310's Avatar
Do you know i can test the pcm?
Old Apr 22, 2013 | 05:17 PM
jonesy9310's Avatar
Anyone know how to test pcm or know what else my problem might be?
Old Apr 24, 2013 | 10:08 AM
cummins_ford's Avatar
with my 7.3 i took the pcm out and took the bolts out and split it in half and if you get a flashlight you can look for burnt out connectors and such or any un normal sighns when you pop it apart. im sure there is a more official way of doing it.. but dealers want a **** ton of money just to eveb touch the pcm
Old Apr 29, 2013 | 01:19 PM
jonesy9310's Avatar
Fixed it ended up bein my gauge cluster
Steve123
Sep 28, 2015 02:36 PM
Powerstroke36
Sep 21, 2015 08:32 PM
MrCat4974
Mar 23, 2015 11:30 PM
Ibanimal
Oct 31, 2014 09:07 AM
hemiheath
Oct 15, 2014 11:49 AM
