NEED HELP WITH VALVE SPRINGS 60#
Old Apr 8, 2013 | 06:14 PM
first-gen-tough's Avatar
Default NEED HELP WITH VALVE SPRINGS 60#
Got a 96 5 speed. getting a bunch of work done to it. Im getting 4000 gov. springs put in. thinking about doing valve springs at the same time. I found some on XDP for $80 for 6. so $160 for all 12. Not sure if they are stock or stronger then stock. They are 60#. here is the ad. anyone know????
BD-Power 60# Valve Springs 1030060
I got 4gsk springs already. just need valve springs that will hold 4000 and be safe doing it. wont ever go that high only at truck pulls
Last edited by first-gen-tough; Apr 8, 2013 at 06:14 PM. Reason: Automerged Doublepost
Old Apr 8, 2013 | 06:22 PM
H.R.D's Avatar
They are stronger than stock, stock IIRC came with 35 lbs valve springs.
Old Apr 8, 2013 | 06:33 PM
awesome thanks. 80 bucksfor 6 a good deal or is there better prices out there?
Old Apr 8, 2013 | 06:51 PM
H.R.D's Avatar
Seems reasonable to me. I would ask for a quote on 60# valve springs in the Price Quote - Request A Price - Diesel Bombers section and see what our vendors can do for you. I know BD is a vendor here, hell you may even get a better deal than what is advertised on their site.
Old Apr 8, 2013 | 07:28 PM
just posted in there. Thanks for the tip!
Old Apr 12, 2013 | 11:33 AM
94 12valve's Avatar
Make sure you get some good retainers with thoes springs some of the stock retainers have pulled through if you reuse them.
Old Apr 17, 2013 | 09:25 PM
mprmn08's Avatar
stock springs are actually around 50# seat pressure, 60# springs aren't actually a real good upgrade, there better then stock but but high boost and high rpm will still float them. There not 60# heavier. for a good spring check out hamiltons or a comp spring with the right installed height and spring pressures.
RA113024
Mar 13, 2016 07:42 PM
Jake12valve
May 10, 2015 11:57 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
POWERSTROKEMANIAC
Dec 30, 2014 11:32 AM
