still not getting enough fuel :/
Old Apr 7, 2013 | 01:35 AM
Gotta<3a12valve's Avatar
Default still not getting enough fuel :/
Based on my sig what am i missing besides injectors .... Rack plug make a noticable diff?
Old Apr 7, 2013 | 11:20 PM
97cummins's Avatar
A 12valve doesn't have a rack plug.
Is your star wheel turned up?
Old Apr 8, 2013 | 05:10 AM
A 12 valve doesn't have a rack plug ! I beleive ur mistaken sir p7100
Old Apr 8, 2013 | 07:08 AM
mysterync's Avatar
Lol yea.... its got one. Did you verify afc travel and that boost is making it to the afc.
Old Apr 8, 2013 | 11:15 AM
94 12valve's Avatar
^ first check that
rack plug does make a pretty good difference 2mm of rack travel IIRC ... but your going to have to mod your afc arm to get the full effect
Old Apr 14, 2013 | 02:31 PM
---'s Avatar
First: I am not sure if you are serious or just joking but if you truly are serious then I would like to politely correct you and let you know there is a rack plug located on the very front of the P7100.
Second: More fuel
1. Crank star wheel all the way up
2. Remove fuel plate
3. Install 2095 rack plug
4. Install adjustable fuel pressure screw
5. Rack barrels
6. Install delivery valves
7. Advance injection timing
That's all that I have done to mine and without spending big bucks on new plungers, barrels, and lines I
believe this is just about all you can do. I don't believe adjusting the AFC supplies necessarily more fuel I think it just changes the curve of fuel flow based on your RPM's. Please correct me if someone knows otherwise.
Old Apr 15, 2013 | 02:15 AM
97cummins's Avatar
Well, ok then, thats a new one on me. Where is this rack plug located?
Old Apr 15, 2013 | 05:15 AM
Let me recap my barrels are racked 4k gsk no fuel plate afc tuned etc
Its come to mt attention my fuel psi sucks i stretched ofv spring and it came alive!! Now need adjustable ofv
Old Apr 24, 2013 | 06:56 PM
kapnhook's Avatar
rack plug is between timming cover and pump,if u look down between them u will see a hex head plug that screws into injection pump,there is a deeper one that alows more rack travel.
Old Apr 24, 2013 | 08:13 PM
94 12valve's Avatar
2095 rack plug is the upgrade plug ... best bang for your buck as they can be had for 12 bucks
