6.5 won't start
Tore my engine apart because of oil leaks now it will not start and it is blowing the gauge fuse I need to get it running cause I need to get rid of a 08 fx4 with a 5.4
This 6.5 is turning over slow I took the 850 amp off my other truck and put that on that helped but it don't turn over long before it starts dragging I loosened one of the objectors didn't see no fuel so I took the line on top of the pump and no fuel is coming out I guess that feeds those 1/4" lines to the objectors
Can you hear the prime pump? There is a oil pressure switch that is wired in series with the prime pump. If this fails or wrongly connected you may loose power to the prime pump. Try to use two long pieces of wire + and - to connect the fuel pump directly to your battery (I'm talking about the fuel pump under the driver seat).
