Confused 94 3500
Old Mar 30, 2013 | 08:07 PM
carolinaturbo's Avatar
Default Confused 94 3500
I have a 94 3500 that will not speed up while in gear till i am rolling a little. It speeds up fine in neutral but if you put it in gear it will not speed up or it does very slow. Acts really week. Changed the pump and injectors. Also put new ops and pmd on. Changed pedal pos sensor also. Only code i have is a 12. Any help would be good, Thanks.
Old Mar 31, 2013 | 06:56 AM
Rattler's Avatar
Have you tried the lift pump test?
Old Mar 31, 2013 | 07:54 AM
I installed a new pump to raise psi. The Psi is around 8 to 10 at idle. I think thats ok. Is that the test your talking about?
Old Mar 31, 2013 | 08:20 AM
Mase's Avatar
I think he is talking about opening the T-valve while truck is running to see if fuel comes out tube or motor dies but if you are getting PSI from LP it should be working.
Old Mar 31, 2013 | 08:56 AM
I tryed that and it keeps running. I dont have any more ideas other than it seems like the fuel timing is off. But if some body knows how to check that please chime in
Jet A Fuel
For Sale
Aug 16, 2015 04:44 AM
jrock0805
Jul 28, 2015 02:03 PM
Jun 22, 2015 12:40 PM
cdpowers
Jan 23, 2015 01:42 PM
DIESELDENT
For Sale
Dec 19, 2014 06:53 PM
