Edge Juicer
Old Mar 28, 2008 | 07:28 PM
Rotty99's Avatar
Default Edge Juicer
Ok so i just ordered mine a few hours ago, the hot upgrade is free for awhile with a purchase of some of edges new items =p might have to go for that..
anyone have any experiance with this program?
its going in my
06 F350 [single tire rear end] - 6'' lift 37'' Nitto's
And anytips on some exhast upgrades would be great id appriciate it, thanks =p
Old Mar 28, 2008 | 08:26 PM
JON's Avatar
JON
Member
Default Um
AFE intake and a 4" turbo back. Cat delete. Muff delete is up to you but highly recomended. Stacks are my favorite.
Old Mar 29, 2008 | 12:45 AM
Rotty99's Avatar
Man i have no idea what you just said
Old Mar 29, 2008 | 01:13 AM
2500HeavyDuty's Avatar
AFE is a brand of an after market intake
and also a 4 inch straight pipe exhaust that removes the catalytic converter and muffler.
Old Mar 29, 2008 | 11:52 AM
Rotty99's Avatar
some guys told me cant pass inspection with out the catalytic converter or something to that effect.. ill check it out tho ill look at some exhaust systems an such an find something thanks
Old Mar 29, 2008 | 12:18 PM
Blue01F250's Avatar
Duramax Virgin
whatever you do (keep the cat and muff or not) just make sure and get a larger down pipe (or DP) - make it a 3.5 inch, or 4 inch if you prefer - 3.5 shoudl help your turbo not lag as much.. either way it will be an improvement and help control EGT's (exhaust gas temperatures) - the bigger DP and exhaust the lower your EGT's should be..thats also why some say to delete the cat and muff as it eliminates ANY restriction your exhaust might have..
if you're worred about emmissions, just use a cat delete pipe thats bolted in with u-bolts and you can remove the cat after your inspection is complete.
An intake such as the AFE will also help lower those temps, and those are the MAIN things you want to control..
also, do you have guages? (can't remember if the juice is guages or not )
Old Mar 29, 2008 | 01:31 PM
Rotty99's Avatar
no i dont have any gauges this programmer is the first upgrade besides lift kit tires an misc stereo eq.
Old Mar 30, 2008 | 06:53 AM
Blue01F250's Avatar
Duramax Virgin
you'll likely want to look into guages soon (boost psi, EGT, and Trans temp) specially with the lifted truck and likely bigger tires -- will be working that trans...
guages are always a good mod to do as one of your first mods - helps you monitor your truck and not melt it down
btw, what do ya do in Deer Park? I have some pipelines I watch down there
Old Mar 30, 2008 | 10:59 AM
Look at some Isspro or Autometer Gauges, MBRP or Silverline Exhaust.
Old Mar 30, 2008 | 10:11 PM
Rotty99's Avatar
well i just left Willbros to be closer to home, now im living in deer park working for Lott Construction doing a 12'' pipeline for chevron
im a line locator
