Slight miss and hard start
Old Mar 21, 2013 | 05:17 PM
eddie7644's Avatar
Default Slight miss and hard start
Ok I have a 96 with only 86000 miles and what is happening is I have to give it slight throttle in order for it to start or it will just crank all day. It also runs a little rougher than it should with a weird noise from exhaust like its misfiring. Now I just noticed when I start it then shut it off I can hear air hissing out of somewhere in the general area of the fuel filter or something around there. My question is any idea where I should start to look for it and if it is leaking air will it cause my problems?
Old Mar 21, 2013 | 05:52 PM
H.R.D's Avatar
Yes air in the fuel lines can cause your issue.
Old Mar 21, 2013 | 06:52 PM
eddie7644's Avatar
Ok any common places around that area that are known to leak air?
Old Mar 22, 2013 | 10:14 PM
H.R.D's Avatar
Your best bet it is take it to someone that has a smoke machine and run some smoke through it to find the leak.
Something you can do yourself is just take a look around and try to locate the hissing noise, look for wet spots and damaged areas.
southeren_born
Mar 28, 2015 09:19 AM
IGOU
Mar 8, 2015 04:25 PM
gator515
Jan 14, 2015 01:56 PM
