I want to make my 12 valve run better!!
Old Mar 20, 2013 | 10:12 AM
Radcummins6's Avatar
Default I want to make my 12 valve run better!!
I have a 94 12 valve cummins bone stock. I want to give the old goat some *****. I'm not looking to make a race truck but what can I do to make her run a little better? Since you can't chip these old goats. Thanks y'all
Old Mar 20, 2013 | 11:36 AM
olsmokey's Avatar
fuel plate and afc housing tune will make it a whole different truck. you can buy a fuel plate. slide the stock one forward or grind your own. first things first i would say some intake and exhuast work. it needs to breath to make power. after that you can start fiddling with power.
Old Mar 20, 2013 | 11:40 AM
So put cold air intake and maybe an aftermarket intake manifold? Would 4 or 5 inch exhaust help?
Old Mar 20, 2013 | 12:22 PM
CR9712v's Avatar
4 definetely.. 5's overkill.
Old Mar 20, 2013 | 01:47 PM
Thanks for advice y'all. Would aftermarket injectors be necessary?
Old Mar 20, 2013 | 02:11 PM
Cumminsaddict's Avatar
cold air intake, 4 inch exhaust, i would grind the factory plate ( just remove a little at a timeuntil youre satisfied) and you will notice a big difference. is it auto or 5 speed?
Old Mar 20, 2013 | 02:13 PM
Automatic I just had the tranny rebuilt.
Old Mar 20, 2013 | 03:48 PM
youll wanna keep it light on power adders then, especially if its brand new
Old Mar 20, 2013 | 03:59 PM
Coco2992's Avatar
4k springs was a nice wake up. im about to add some injectors in today
RA113024
Mar 13, 2016 07:42 PM
vin_diesel
Mar 1, 2016 01:43 PM
Baradium
Mar 9, 2015 07:15 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
