Strange fuel issue/bad sensor? 01 24v
Old Mar 13, 2013 | 09:57 PM
pdx_marc's Avatar
Default Strange fuel issue/bad sensor? 01 24v
Okay, so I posted a while ago about my lift pump problems. After getting a fass ddrp my problem still consists. How about this one though:
I hard wired my LP, constant 15psi. Drops no less then 11 under wot.
Starts, runs and drives fine till its warm. Then back to stalling when I go from park/neutral to reverse or drive.
After it stalls it will not start unless I unplug my LP and then it starts right up and runs great, while its running I plug the LP back in and and it runs rough.
I just changed my cam sensor, I think I'll do the iat and maybe a coolant temp sensor.
Before I go any further, has anyone felt with this or know how to fix it?
Btw cold starts fine with LP running.
Old Mar 14, 2013 | 10:48 AM
MillerBoyzDiesel's Avatar
Sounds like your injection pump is trash. There is a diaphram between the low and high press side of the pump that ruptures and will cause a hot no start problem. You can band aid it with a relay that kills power to the lift pump while cranking.
Old Mar 14, 2013 | 10:52 AM
pdx_marc's Avatar
That's what I'm afraid of. Cheapest shop around charges 1500$ for a vp + install
Old Mar 14, 2013 | 02:45 PM
get one frm throughbred 975 shipped last time i looked. r&r is pretty simple
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
J. Nick
Apr 25, 2015 05:01 PM
moneypitk5
Feb 12, 2015 11:01 AM
