Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
How much is too much gasoline in a waste oil blend?
Old Mar 10, 2013 | 11:12 AM
Beyond Biodiesel's Avatar
Default How much is too much gasoline in a waste oil blend?
Blending gasoline at 20% with WVO has worked pretty good for the last 6 years for my old 6.2L Detroit Diesel engine; however, going over 20% increased the likelihood of injector pump failure.* So, I recently made up sample blends and put o-rings: Buna-N 70, Silicone 70, V75 Viton in them and left them to soak.*
Stanadyne DB-2 injector pumps use both Buna-N 70 and Silicone 70 o-rings.* I found in my experiment that Buna-N 70 o-rings can handle blends containing up to 50% gasoline; however, I also found Silicone 70 o-rings will swell significantly in blends containing 40% or more gasoline; whereas, blends containing 30% or less gasoline will not swell either o-ring; and V75 Viton will not swell. Please photo below:
Source:
Old Apr 3, 2013 | 07:35 AM
louisfepetit's Avatar
Banned
Your fresh take in this material has a lot of thought-provoking ideas that really took me by surprise. I share your thoughts on many points. You really made me think.
Old Apr 8, 2013 | 09:10 PM
yrkdmax's Avatar
Thanks for testing this!
Old Oct 28, 2014 | 02:01 PM
fijitec's Avatar
interesting
vin_diesel
Mar 1, 2016 01:43 PM
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
