Whistle at turbo.
Old Mar 3, 2013 | 01:30 PM
Ranch97's Avatar
Default Whistle at turbo.
I have a 2006 f250 with 6.0. Have installed EGR delete and SCT programmer. I have a loud whistle coming from turbo area. IT only whistles when your foot is on throttle but stop around 2000 RPM. ANy ideas?
Old Mar 3, 2013 | 03:09 PM
POWER-STRUCK's Avatar
turbo exhaust leak could be the cause.
Old Mar 3, 2013 | 03:12 PM
Ranch97's Avatar
From the down pipe?
Old Mar 3, 2013 | 03:39 PM
Al31031's Avatar
is it more of a whine or like a whistle could be your turbo bearing or could be the y pipe wich is extremely common on the 6.0's
Old Mar 3, 2013 | 04:03 PM
Ranch97's Avatar
Checked bearing in turbo it seems fine..
Old Mar 3, 2013 | 04:09 PM
exhaust leak anywhere on the up pipes or a loose egr block off plate
Old Mar 3, 2013 | 06:57 PM
Ranch97's Avatar
Found no exhaust leaks or EGR plate loose.. Did find small leak in pipe going from turbo to air cooler.
Old Mar 3, 2013 | 07:10 PM
the cac hose can cause a bit of noise if it has a leak!
Old Mar 3, 2013 | 07:21 PM
Ranch97's Avatar
Ok thanks.. I'm going to drop it off in the morning to have it looked at..
Old Mar 7, 2013 | 10:50 AM
Ranch97's Avatar
FOund Y pipe cracked. installing new Y pipe and SCT fitting up date on oil pump.
