Time for injectors.
Old Feb 25, 2013 | 07:13 AM
01freeman's Avatar
Default Time for injectors.
I am looking to upgrade my injectors they are stock on a 185,000 mile truck. I have exhaust, smarty, S300 turbo I am looking for bigger injectors for more power for pulling my trailer right now. Then later add twin turbos and some more engine mods. What is a good injector to install. for an extra 50-100hp.
Thanks
Old Feb 25, 2013 | 10:35 AM
jkidd's Avatar
There are lots of options. I would look bigger if twins are in your future. Depending on what size of s300 you have I would look at closer to 150HP and just turn your box down until you get twins, or if you are towing heavy.
Old Feb 25, 2013 | 01:08 PM
01freeman's Avatar
I usually tow heavy. the turbo specs are 62/65/12 s300.
I guess I need to know what brand and size injectors, price and can this turbo be upgrade to bigger compressor or turbine, housing etc if needed and what size.
Thanks
I usually tow with the truck. I am looking for some more power by upgrading the stock sticks
I have a 01 6 speed H.O. i want to upgrade the stock injectors. i currently have 62/65/12 s300 exhaust, fass 150, what size injectors, brand, prices do you recommend. Im looking for quality. i tow with it alot and want to upgrade to twins in the future with 500ish rwhp. but for now just a set of sticks that will increase my power. also is there another programmer I can run. i currently have a smarty on the truck. Any suggestions.
Thanks
Old Feb 27, 2013 | 02:08 PM
jkidd's Avatar
125HP injectors and a smarty/edge stack will be 450HP or more. I would go with 125- 150HP injectors and possible go bigger when you do twins , or go with the big injectors sized for 500HP twins (175HP) and run the smarty on 1/2 power setting. We have all sizes in stock.
Old Mar 8, 2013 | 04:58 PM
01quadcab's Avatar
my 62/71/14 and ddp 110's made 488 but it's was an so automatic truck. I liked my ddp's they were pretty clean once my turbo spooled but it was a bigger housing and bigger turbine than what your running so spool up is a lot quicker. then later add a bottom turbo and some bigger sticks that turbo you have will be great paired with a s471
Jul 20, 2015 01:20 PM
1969olds
9
Apr 18, 2015 02:59 PM
Mar 27, 2015 07:20 PM
Mar 19, 2015 08:10 AM
Nov 11, 2014 04:10 PM
