01 cummins lift pump issues
Old Feb 11, 2013 | 11:54 PM
pdx_marc's Avatar
Default 01 cummins lift pump issues
first off, I have been searching google, forums, etc for anything that's remotely similar to my problem.
01 24v
all stock other then exhaust.
oem, block mounted LP started loosing pressure. I goto my local parts store, buy a new one. Installed with no issues, blip the key to prime/bleed off air. Pump runs for the normal 20 seconds but only made pressure for about 10 sec, then nothing. Okay, bad pump. Cruise back down and swap out pumps. Install new pump, primes has pressure, starts. Drive once. round trip of about 2 miles, get home and it ***** out again. Okay so I go back to the store and they upgrade me to a carter pump. Put that in and I see a huge difference. Next day, I drive about 5 miles and it ***** out again!
yes, I know I should just buy a fass and get it over with but times are tough and its not possible for a few weeks.
anyone else have this problem or know what could be causing this? am I just getting **** pumps? I'm at a serious loss right now and overly puzzled.
thoughts?
Old Feb 12, 2013 | 12:03 AM
H.R.D's Avatar
May have some trash in the lines or tank that is causing the pump to crap out on you or you could just have very bad luck with stock pumps. Like you said above you need to get an AD or Fass. Have you check and/or changed your fuel filter?
Old Feb 12, 2013 | 12:10 AM
pdx_marc's Avatar
filters new, during the first pump swap I blew the lines out and there was no blockage.
also I run bout 1/2 qt atf every other fill up to keep the vp happy.
Old Feb 12, 2013 | 01:29 AM
GuyWithA24Valve's Avatar
Don't run ATF. New ATF has friction modifiers in it, and that's really not good for the VP44. It's possible that the ones you replaced could have been bad too right from the start.
Sent from my iPhone in the cab of a Caterpillar
Old Feb 12, 2013 | 01:36 AM
pdx_marc's Avatar
noted! any sensors,etc that may be causing this or am I bad luck?
Old Feb 13, 2013 | 03:48 PM
pdx_marc's Avatar
Bump, anyone?
Old Feb 14, 2013 | 05:16 AM
charlie m's Avatar
Make a temporary suction line from lift pump to a clean bucket with some fuel in it. This will eliminate the truck, so it will give you a direction to go. GOOD LUCK
Old Feb 16, 2013 | 01:01 PM
cummin_un_glued's Avatar
FormerVendor
also check the voltage at the lift pump i have seen a few cases where the lp circuit in the ecm go's bad and dosnt supply 12v to the lift pump and requires having the ecm replaced
Old Feb 16, 2013 | 02:29 PM
charlie m's Avatar
Also load the 12v with a light. A dvm will read 12 volts with one strand of wire left
Old Feb 17, 2013 | 12:00 AM
pdx_marc's Avatar
If voltage were an issue wouldn't it not turn the pump on?
Ill check in the morning either way
